BluOS - when will the issues be fixed?
    Hi Flamur
    1) The volume on your now playing screen on your iOS device is caused by using large text on your phone or iPad from Settings, Display & Brightness - Set it to Default Text to resolve but this is an iPhone/iPad universal setting. Look for a fix in the next iOS App later this week
    2) Just a reminder that Spotify Connect means everything, including search, in Spotify is controlled by Spotify. The only options in the BluOS App is Play/Pause, Grouping and volume control.
    3) On the Search Tab, be sure you are set to TIDAL as your music service using the top right Source selector.
  • Flamur Abdiji
    Found a way around the searching not working. Disable the new interface. But even on the old interface - volume is not reachable.
    Guys - I know we can do better than this. Your products are great so we need to follow with the software.
  • Bodi
    I'm not so sure Bluesound can do better than this. Looking at all the weird and different problems on Win/Mac/IOS/Android and across their products it's clear to me they don't have that solid framework they were boasting about when releasing BugOS 4.0. Their current update schedule is embarassing. They should be releasing fixes at a faster rate, even it was for a small gui change of whatever, just to show their users that they care. But they clearly don't.
    2
