Volume Leveling
BeantwortetAs many of us do, my digital collection volume level varies from album to album.
I use an external DAC so using the Volume Limits feature is not possible, or so it appears.
Is there a control or feature available that will allow me to equalize the volume of my files?
Thanks for the info!
I had it set on Smart Gain, however, I have some albums that are definitely louder than many of the others.
So how do you adjust ReplayGain values within BluOS? Or can you?
Thanks.
I will go search for a tool to use then.
