Pulse Flex and Node 2 are not working anymore
BeantwortetI have a Node 2 and a Pulse Flex. The controller app does not see them anymore and does not work properly. Nothing changed in my WiFi network. I tried all the reset possibilities, but nothing helps. The blue light on the Node 2 remains 'on' but will not connect in the iPad app or Blue OS controller on my Mac. There is no music from Deezer and no Radiostation. Strange, this never happened before. I really don't know what to do....
Gertjan Withagen, The Netherlands
Hi Gertjan
Your App is not communicating with the Players likely due to a network collision or network traffic. Please reboot your router, wait 5 minutes, reboot your player, wait 5 more minutes then relaunch the App. If problems persist or return, please e-mail support@bluesound.com.
Thanks Tony,
the PulseFlex is already working again, after I disconnected the Node 2, because of the blue light (trying to reconnect?) which was continuously turned on. So the two players were 'ungrouped'. Tomorrow I'll try the same with the Node 2, without the PulseFlex. Maybe the Node 2 has a problem, causing a not properly working group.
Your NODE and its power supply are designed to be always on and always ready and meet EU requirements as an eco-friendly network appliance. It will go into a low-level stand-by if idle for 15 minutes. If the LED is bothersome, you can disable it in the Settings menu under Player.
Tonight I found out that the Pulse Flex is working fine now, when it's the only player that's connected. I followed your instructions, also by starting up the Node 2 (as the only player), but when I tried this player it doesn't want to connect. The light stays blue after starting up (first red and different lights, as usual). So what can be wrong with the Node 2?Kind regards,Gertjan Withagen0
4 Kommentare
