Resetting problem Vault2
First of all its a problem how to know which generation a Vault2 is? Anyone?
Reset does not work, I tried both, led of play / pause button stays red all the time after reset effort.
Also after changing to wired internet.
Really need help!
Thanks.
Rinus
the Netherlands
The model number should say on the back of the device under the company information. See the image below for reference.
Here's our KB for performing factory reset - https://support1.bluesound.com/hc/en-us/articles/200272046-How-do-I-perform-a-factory-reset-on-my-Bluesound-Player-.
If you require assistance, please don't hesitate to reach our support team by creating a support ticket either by sending us an email to support@bluesound.com or by using the BluOS app, BluOS >> Help >> Send Support Request.
Thanks for #LivingHiFi -
I'm having the same problem, after doing a reset the system returns to steady red light.
This started after trying to do a system update.Will
USA0
