Connecting to mobile device hotspot
BeantwortetHey,
Quick question here. Is it possible to use your mobile device as wifi source for your powernode 2i?
Gr!
The source of wifi and controller can't be the same?
Thx!
If it needs another device. Would it be possible to connect a portable audio player with a cable to the powernode? And how would I be able to do so without impacting audio quality?
Gr0
