Tone control impact on POWERNODE (N330)
  • energyd
    I guess if you want neutral sound you want to turn everything off
  • Stanley Goldfader
    I have found that the sound is clearer with tone “on” and 0 db. No drop in volume.. might even be a db louder when On
  • ALI NAQVI
    Interesting, I shall try that too and see if I can hear a difference.
    At low volumes to give the sound more depth, I tend to set the bass at 4 and treble at 2 which works for me. And then when I want to blast it out I go back to the default settings as this seems to unleash the vocals. If I keep the unit set at 4 & 2 there's a slight tendency for the vocals and mid ranges to sound like they are being generated from behind a curtain. There's just more transparency and a better sound stage at high volumes when using the default settings.
