MacOS 3.20.1 problems
5 comments
    Mark T.
    Sr. Support Crew Member
    I am escalating your feedback to a support ticket. A member of our support team will reach out to you soon.
    Thanks for #LivingHiFi
  • MarkoF
    I'm having similar issues with lack of functions or updating of the play controls after computer sleep on an iMac (OS 11.7.1).
    Access to more reliable versions could be good alternative until a fix is in place.
    Mark
  • Simon B
    I have the same issues. Every time when I wake my Mac the app UI does not update. Pressing Play usually starts my speakers playing, but the app shows no progress, play queue does not change, Play button does not change to pause icon.
    I have to quit the app to make it work properly. That is a real hassle because the app is not good at remembering state
  • ronald
    Same here, for Windows 11, BluOS-Controller-Setup-3.20.1.exe.
  • Max Dekker
    Same here on Windows 10.
