Bluesound Node n130 MQA RCA OUT
AnsweredBuenos dias a todos, tengo una duda sobre el funcionamiento de mqa y las salidas RCA cuando MQA external DAC esta acitvado, tengo un dac mqa decoder en la salida optica y marco MQA external DAC, pero mi duda es si activando MQA external DAC en el bluesound sigue decodificando mqa a la salida RCA. Gracias a todos.
Good morning everyone, I have a doubt about the operation of mqa and the RCA outputs when MQA external DAC is activated, I have a dac in the optical output and MQA external DAC frame, but my question is if activating that for bluesound continues to decode mqa to the RCA output. Thank you all.
This explains the settings.
https://support1.bluesound.com/hc/en-us/articles/115006191908-Why-Isn-t-My-External-DAC-Playing-MQA-
Good afternoon and thank you for your prompt response, but that article does not answer my question or I did not understand it well. I just want to know if when I check the MQA external DAC box and my dac full decoder connected by COAX decodes the signal, the NODE for its rca output that also plays the music is also decoding on that output and I get the maximum quality for RCA. I don't know if I explained it well. All the best
Buenas tardes y gracias por su pronta respuesta, pero ese articulo no responde a mi pregunta o no lo he entendido bien. Solo quiero saber si cuando marco la casilla MQA external DAC y mi dac full decoder conectado por COAX decodifica la seƱal, el NODO por su salida rca que tambien reproduce la musica esta decodificando tambien en esa salida y obtengo la maxima calidad por RCA. no se si me explicado bien. Un saludo
If your DAC is MQA compliant then you follow the instructions in the link above.
The RCA sockets always provide maximum quality.
Thanks for your reply, so I understand that the MQA external DAC slider is irrelevant to the RCA outputs. The RCA outputs always decode MQA.All the best
Gracias por su respuesta, entonces entiendo que el control deslizante de MQA external DAC es irrelevante a las salidas RCA. Las salidas RCA siempre decodifican MQA.Un saludo
4 comments
