Sound level
AnsweredGot reply gain set to smart gain on reading other posts seems to be the best setting.
Using tidal (not sure on other streaming services) why is there still a large difference in volume between a song that is in cd quality and one that is in master/mqa, is there some other option I can turn on or off, it's very noticeable and getting annoying.
Unfortunately this is down to Tidal and there is nothing you can set on BluOS to help. Spotify has a normalisation function but not sure of other streaming services.
If you use an IR remote such as the RC1 from Bluesound you could set a preset with a lower and one with a higher volume setting to instantly tweak the volume down or up. Or just using the RC1 is very quick to adjust the volume.
