TIDAL CONNECT: My Bluesound Node 2i is not appearing on the sound output list
AnsweredI know i am not the one who the issue. Please do something on this.
I am on android 12 then updated to 13 and still the same. It works before on android 12 but recently(last week) node 2i disappears on the list and I cannot find it.
Sometimes it will pop up but if I connect, it shows connected but no sound is playing?
Hi Epol,
Please try these troubleshooting steps to fix the issue.
1. Perform a network reboot.
2. Rename Bluesound player from the BluOS app.
3. Try re-installing the Tidal app.
If issue persists, please send support request using the BluOS app. Then we can diagnose the issue.
Thanks for #LivingHiFi -
I tried it all. No luck :(
Hi there, same issue here with my powernode n330 and tidal connect. I cannot use tidal connect anymore even if the player is displayed on their app. I also sent a request to Tidal support.
Hi Vincent,
Try re-installing the app and see if that helps, otherwise, please send a support request using your BluOS app.0 -
I have the same problem. Bluesound node 2i doesn't appear in Tidal. Works perfectly on Spotify.
Same problem. I submitted request for help over 48 hours ago. I will not be recommending this system to anyone
22 days later????????/////////////???????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????
Bluesound NODE sucks. That's the case. Tidal connect has stopped working normally on Android and on iOS as well.
8 comments
