BS Node N130 no sound to Holo Audio Spring 2 L2
AnsweredHi All
Hope someone on here can assist. I have the new Node with the latest firmware update and I have checked with Holo Audio and i also have the correct firmware update being 30.14 for the Spring 2 L2 Dac.
I am not getting any audio at all the to HOLO, on the Node it pick up the USB out to the holo and on the HOLO screen it shows DSD 512 but no sound at all.
I though possibly it was a cable issue but have tried various cables with no luck. The node seems to restart itself when when i chose the USB out to the HOLO. Then also getting an error on the app stating no audio to output.
Via Digital out i dont have any issues at all.
Did anyone else have the same issue that they managed to resolve?
I see on their Website several firmware versions are available, might be worthwhile asking them if you do have the latest version and that its for fixed volume use.
Why is the DAC showing DSD 512?
Thats the max sample rate on that input. Dont know if it shows that due to the USB connection.
I have checked with Holo and was advised i have the correct driver. Will check a different version and see if that works
Hi
I have a Holo spring 3 L2, the firmware is 30.14 and usb gen 2.0, with the same issue.
Which version firmware or driver did you change to?
Thx.0
5 comments
