Bluesound Remote Control RC1 for my Bluesound Pulse Flex 2i (Stereo Pair)
AnsweredHello,
I just bought Bluesound RC1 Remote Control for my Bluesound Pulse Flex 2i Stereo Pair. I think I've got it set up right but the RC1 does not work properly .
Now I can't find out where's the Remote Control configuration menu in the BluOS app. Does anybody know how to make the Bluesound RC1 Remote Control work ?
With kind regards,
Sjors - The Netherlands
Settings…Player…IR Remote and then toggle on “Enable BluOS Remote”
From memory there is a plastic tag to pull out from the battery compartment.
Thank you. It's weird maybe but I really can't see Player menu in Settings...
Suggest you unpair your Flex’s powercycle them and then see if the menu appears.
I've tried and it's working now. Thank you very much
Now it's again starting to dysfunction. Maybe it's something to do with the Remote's Channel (set on "0"), could you tell me what's that for ?
And now, it seems it's working again. Maybe it takes some time for the settings to take place
You may want to replace the supplied batteries as their age in unknown and could have been in the store for a long time before you received it.
Thanks, but this doesn’t seem to help either
Best log a support ticket, from the Bluesound App select Help…Send Support Request. Do this after using the RC1.
9 comments
