Bluesound Node & Leak Stereo 130
AnsweredHi all!
Wondering if anyone might have a suggestion/solution for my description below. I've also included images of the devices and my current cable setup. Thanks so much in advance for reviewing!
When I open the iOS BlueOS App and choose a track from Tidal or Spotify, the Node wakes" the Leak Stereo 130 from standby mode and starts playing the track within 2-3 seconds since I have a 12V audio cable running from the Node Trigger Out to the Trig In on the Leak Stereo 130. I have the Node set to Output Level Fixed with the volume turned all the way up.
There’s one limitation I’m running into though… The Node volume is set to maximum and the BlueOS app is set to Output Level Fixed. The Leak Stereo 130 volume can be controlled by its own remote, but I want to find a way to control the volume on the Leak through the BlueOS app (or perhaps a different iOS app). Which seems possible since the Leak has a decent variety of ins/outs.
Would love any ideas/solutions for this. Thanks again for reading!
Set the 3rd party receiver to your maximum desired volume level and use the variable output on the NODE and use the volume slider in the App. That being said, I would only do this if the NODE is your ONLY source on your receiver (based on your illustrations, it looks like it very well may be).
