LG C9 eARC pass through not working with Powernode (2021)
    Mark T.
    Sr. Support Crew Member
    Hi Dmytro,
    I'm escalating your request to a support ticket in order for our support team to investigate.
    Thanks forĀ #LivingHiFi
  • Jonathan Anderson
    I may have the same / similar issue and add information to it.
    I am using an LG C9 with eARC to powernode.
    It seems to work well mostly.
    There is one annoying issue. When using amazon prime app on to stream video, with sound out to powernode it works good until amazon switches episode. The sound then goes from good sound to screeching vibrating noise. Pressing up / down volume on the tv returns the sound to normal. Would be great if you could help troubleshoot what the issues is. Is it the powernode, the tv or the amazon app? Kindly, Jonathan
