audio settings connects to wrong player
    Mark T.
    Sr. Support Crew Member
    Hi Edward,
    Make sure that your BluOS app is updated. I have 3.18.1 and I cannot re-create your issue.
    Thanks for #LivingHiFi
  • Thomas A.
    Hello,
    Yes i have seen this too. In sound settings the wrong player is sometimes opened. This started with the 3.18.0 update.
    For example, if I want to enable or disable Dirac, I sometimes need 3 attempts to reach the right player 🙃
    Tone controls and balance dito does not work correctly either.
    My devices looks like this: C658 in the living room ... 1 Pulse mini in the workroom ... 2 Flex paired in stereo in the kitchen...all wired
