Does usb out work now?
AnsweredJust read through all the comments regarding usb out to an outboard dac. Seems like you're still having problems, or is this function now working properly?
Hi Mark,
You can learn more regarding USB out through this link - Node Gen 3 future USB output – The Bluesound Support Crew.
If you are having any issues, please send a support request using the BluOS app, BluOS App >> Help >> Send Support Request. Also, in the description of the issue, make sure to put in the USB DAC that you are using.
Thanks for #LivingHiFiComment actions
Post is closed for comments.
