Does usb out work now?
    Mark T.
    Sr. Support Crew Member
    Hi Mark,
    You can learn more regarding USB out through this link - Node Gen 3 future USB output – The Bluesound Support Crew.
    If you are having any issues, please send a support request using the BluOS app, BluOS App >> Help >> Send Support Request. Also, in the description of the issue, make sure to put in the USB DAC that you are using.
    Thanks for #LivingHiFi
  • Mark Jaffe
    I'm refering to problems with usb out on the new node.
  • Invenio
    Yes, it works. I've been using it for months. N130 unit.
Post is closed for comments.
