Delay using my mixconsole
7 comments
  • Mike
    Ok..no solution possible, maybe connect my speakers on 2 receiver and switch between them?
  • Mike
    Can i connect a amplifier to a node?
    Is delay gone if i use my mixconsole?
  • Mike
    Is the powernode also able to connect with a amplifier?
  • Mike
    Ok sounds intresting, and the soundquality depend on the amplifier that is connect, i have a new pair of Dali Oberon 7, mayby my old Nad c372 wil do the job, i think i bring my powernode 330 to the store and ask for the node , 2i is the good one right?
  • Mike
    That is a good idea, can i connect the powernode to the node?
  • Mike
    And is there no delay using the c372 and the node?
  • Mike
    thanks for the information much appreciated :-)
Post is closed for comments.
