Technical question on AC Inlet polarity on VAULT 2
AnsweredHey Guys,
is anybody here able to 100 % confirm which of the 2 pins of the AC inlet ist the hot (+) pin, the left or the right pin?
Thank you.
Best, Uwe
Bluesound Players use a switchmode power supply - it does not matter.
HI Tony,
it's just as I do correct phase setup to all of my other components in the audio chain, that's why I've asked:
Thank you for your quick reply.
BestUwe from Berlin
