Node errors out while setting up airplay with “unexpected error”
First time setup of my N130 and not having any luck. This should be plug and play and it’s far from that. I have an Apple TV on the same WiFi network and that works fine and was simple to setup. Am I missing something? Seems that BlueSound could do a better job on error handling so we actually know what this error is.
Escalating your request to a support ticket. A member of our support team will reach out to you shortly.
Thanks for living HiFi!! -
This a starting to look like a possible HW issue. So far I am very very unimpressed with BlueSound as a whole. The UI looks like it was made by a third grader. Not sure how these sell for $600.
Temporarily run an Ethernet cable from the Node to your router, you will then be able to enter the Wi-Fi credentials using the Bluesound App.
Likely that your router needs some settings changed so if the above does not help drop Bluesound an email to
