Pulse Soundbar+ and AppleTV doesn't play 5.1 sound properly
    Mark T.
    Sr. Support Crew Member
    Hi Patrik,
    We are seeing this behavior with Apple TV4k and are able to recreate it in our test environment.
    In some third-party services ( Netflix, Disney+, Prime) the ATV4K outputs PCM Surround instead of Dolby or Dolby Atmos.
    Instead, the ATV4 should be outputting Dolby/Dolby Atmos as Bitstream. This is a bug in the ATV4K firmware and there are no settings to prevent it from occurring.
  • Patrik Kähäri
    Aha. After some additional investigations I discovered the following:
    1. Pulse only supports digital formats (Atmos, DD, DDPlus etc.)
    2. Setting AppleTV to sound output Auto will make AppleTV select the "best" sound quality possible
    And when a Dolby Digital source is played, AppleTV converts the output to multichannel PCM. And the Pulse doesn't really do well with PCM-based formats.
    If I override the sound output of AppleTV and set it to Dolby Digital, it works fine since everything is converted to DD. On the other hand, I lose Atmos playback capability.
    A workaround, for the time being, is to change AppleTV settings whenever I want to enjoy Atmos and keep Dolby Digital as the default setting.
    Any plans on supporting multichannel PCM audio in the Pulse Soundbar+ in the future?
