Slow connection to apps and fast drop outs
Followed by 3 people
    Hi Peter
    Your symptoms are all cases of an error in your router's stored network table. Please reboot your router, wait 5 minutes, reboot any wireless extenders you may have, wait 5 more minutes then reboot your Bluesound NODE. This will resolve any networking issues you may be encountering. If problems persist, please select Help, Send Support Request in the BluOS App so we can review further.
  • Haubertpaul
    I have seen comments concerning poor connections on wifi and would like to share my fix to poor connection and app interface. I have a Linksys router though settings should be similar for other routers.  My router had Media Prioritization and Air Time Fairness turned on. I turned both off and now my Node connection and control are both rock solid. I use the android and Windows app. Not sure which setting was causing the problem. It's worth checking out.
