Powernode 1 connecting with turntable
AnsweredHallo, sorry for my poor English. I want to buy a turntable and connect it with my powernode 1. Is their a way to do this because there is no analog input. Thanks for helping me.
Hi Jelger,
There is no direct way to connect the turntable to POWERNODE1. One workaround that can work is by using a Bluetooth adapter to connect the turntable to the POWERNODE. -
Thanks Mark for your quick response. Probably will give it a try but it will not give the best sound quality.
