Any issues to be aware of when using two Nodes?
I'm putting together a small hifi for a guest bedroom. OK, it's also for me when I can't access the system downstairs. So far, I have a good DAC/headphone amp and some new Meze phones and I'm using LDAC Bluetooth for music streaming from my phone. I'm now thinking of getting a second Node as a higher res source. Are there any issues I need to be aware of if I'm switching between two Nodes to use the two systems? Can I name them differently in BlueOS?
Yes you can name each device in BluOS.
On your phone you can then select which one to control from the Players drawer. Here is an iPhone screenshot of my current setup.
Thanks braino. Just to say I bought a second Node (2021 version this time) and set it up today. It was a very easy and quick process to integrate it into Blueos and my music library. As above, selecting between the two devices couldn't be simpler.
"One is too many, One thousand are not enough"
