Another 4ohm question
AnsweredSo I want to get the powernode 331. I see published specs at 8ohms.. I understand there have been several questions regarding 4ohm performance. I do see 4ohm peak #'s, and that is great. I think some of the confusion surrounds NAD's typical published specs for their amps. Most NAD amps have kept the same output and distortion numbers at both 8 and 4 ohms. This held true with the two past direct digital amps NAD has released the M2 and the C390dd. Now... I am running Canton chrono 536.2 bookshelfs, and I will high pass them at 80hz...so I do understand I will be taxing the 331 less. HOWEVER...again...it is typical of NAD to show both 8 and 4 ohm output and distortion numbers. I have little doubt the 331 is perfect for my 2.1 tv system....but WHAT ARE the nominal 4ohm numbers for the powernode 331?
Hi,
I see that you've already submitted a support request regarding your question about the POWERNODE 331's 4-ohm specifications.
Please continue working with our Support Crew through your existing support ticket, as they will be happy to assist you further.
Thanks for #LivingHiFi -
Oh...I have tried to hit this from several different angles and methods. I simply want to make sure...
