Volume control with local files keeps going back to 100%
AnsweredHello,
When I play music from a local hard disk, it all works fine. However, when I set the volume control, it keeps going back to 100%.
When I slide the volume bar, the volume does in fact go down. But then when I click the volume control, its back at 100%. After that, when I want to lower the volume, it will be very loud for a split second until it reached the volume I set it to. Any fix for this?
- iPhone 12 mini
- IOS app version: 3.16.2
- BluOS version (Node 2i): 3.16.5
- Wired connection to router
- Never had this issue before till recently
I am escalating your request to our Support Crew for more details. They will be in touch via e-mail.
Post is closed for comments.
