Bluesound Node N-130 Endpoint Connection Timing to Roon for Linux
AnsweredI have been using Roon for Windows for several years and never have any issues connecting to the Bluesound Node N-130 endpoint. Since I upgraded to Roon for Linux I am having issues when trying to see or connect to Bluesound Node N-130 from Android or iPhone iOS. Occasionally it does not see the Node only the Airplay Node. I then have to reboot the Node and all is fine.
Doing some research, it points to BluOS. Is this a known issue?
Thanks, Ron
Hi Ron,
Since the issue started after switching from Roon for Windows to Roon for Linux, I’d recommend reaching out to Roon Support for further assistance. Their team would be happy to help you troubleshoot this.
Thanks for #LivingHiFi
