Intermittent Static Through Analog In Powernode
AnsweredHello - I am running a turntable to a phono preamp which is then plugged (via RCA to 3.5 mm) into the "Analog 1" input of my Powernode. I have started to get intermittent static noises while having the Analog 1 input selected. This happens both when I am playing the turntable and when the turntable is turned off. Any ideas? I can no longer listen to my turntable because of this static sound (which, again, is intermittent but nonetheless cannot be ignored). Thanks
Sounds like a bad cable or bad connection. Replace the cable and restart your POWERNODE by selecting Help, Diagnostics, Reboot.
