Bug when changing volume, is this a known problem?
4 comments
    Hi Maarten
    Please ensure you are on the latest version of the iOS App from the App store. If problems persist, our team would like to see a copy of the BluOS Event log by selecting Help, Send Support Request in the App,
  • Maarten Klap
    Thanks for the response.  For the logs see the case with number  #260758
    Our Support Crew will take it from here...
  • Maarten Klap
    For wat it’s worth. I noticed that when I start the radio preset in the morning the volume can be changed by remote control without it becoming too loud. It looks like the ios app remembers the high volume settings of the previous evening and that the lower volume of the radio preset is being send/received by the app an therefor when the volume is changed in the app, it sends the wrong volume to the amplifier.
    amplier = T758v3, updated to lates firmware, bluos version 3.16.5
    controlled via iPad (8th generation), ios 15.3.1, bluos controller 3.16.2
