Consistent gravelly fade-in of audio stream across several players - buffering issue?
4 comments
    Something does sound off here but our Support Crew will need to take a closer look. Please select Help, Send Support Request in the BluOS App. In the brief description field please enter exactly as typed the following string (lowercase and with the underscores);
    _alldiscovered_
    This will send us the log files to all your players so we can check if there is a buffering or timing error.
  • Jp-lee
    OK will do Tony. FYI,  I have narrowed things down a bit with more testing, and want to get things down in writing, which I might be able to refer to later. I have three devices.
    • Node 2 which is hardwired - never any problems ever. Relatively short run of network cable (~20 ft).
    • BluOS MDC module (orig version) in my M32 - hardwired - has problems. Relatively long run of network cable (~50 ft)
    • Pulse Mini - wireless - has problems. About 40 feet from base station on same floor.
    The problem is repeatable, but not always. If I play from my Library NAS, no problems. If I stream TIDAL, occasional problems. Let's say I have a bunch of songs in my play queue, and I randomly select songs from it to play. Sometimes I will get the fade-in problem for song "X", then go to song "Y", then back to "X" and the problem disappears. Then I go to songs "A", "B", "C" (no probs with any of them), then back to "X", and the problem reappears.
    It feels like sometimes the initial timing is off a hair, and it's noticeable where the song has music from the get-go. Then the song gets into the buffer, and it's fine If I try again and it's still there for a little bit, but then gets pushed out, and if I go back after a few more songs, I notice the problem again.
    Trying to capture this notion into a clear and concise message.
    JP
  • Jp-lee
    Issue is NOT ANSWERED. I sent in my logs and have heard nothing. Well over a month ago. Nothing in reply. It’s quite frustrating. Constant reminder every time I listen.
    jp
  • Mark T.
    Sr. Support Crew Member
    Hi JP,
    Escalated your request to a support ticket. One of our agents will reach out to you soon.
    Thank you for living HiFi!
