Issue with Ehernet
AnsweredHi
Since I applied the last upgrade, I can't find my Bluesound Node (wired) anymore in the app. I have done a factory reset, rebooted my internet box. When I finally configure it in wireless mode, it's working fine, but after that, when I am connecting the ethernet cable again, the Bluesound Node stops working, it disappears again from the app and I can't find it anymore (although the LED is solid blue). Only the wireless mode is working.
Sébastien
HI Sebastian
We have been able to replicate this issue here in our BluOS Lab - look for a software patch, BluOS 3.16.7 in the coming day or so to resolve this issue. We do apologise for the inconvenience...
Thanks Tony, as I said, it's working fine on Wifi, so not a big issue if this is solve in the next days.
Hi Tony, I've ordered a new Bluesound Node, it will be arriving this Friday 2/4. I was planning on initially configuring it with wired Ethernet. After reading your comment to Sebastien, should I configure it with WiFi until this patch comes out? Or do you think BluOS 3.16.7 will be out by this Friday?
Tom
Hi Tony, I have applied the patch 3.6.17 but this is not solving the issue unfortunately
Hi Sebastien, sounds unfortunate that wired Ethernet is not working. Do you think this is wide spread or isolated. I'm wondering which way I should go, Ethernet or WiFi?
Hi Tom from my part, with my HiFi installation I don't hear any difference between Wifi and wired. I have read somewhere that the Bluesound is working in the same way, with same results even for HiRes files, but I let Tony answer on that point
Thanks Sebastien, hopefully Tony will chime in with direction.
Then it may be just a bad cable - replace the cable and if problems persist, please contact our Support Crew at support@bluesound.com
They just updated my delivery for my NODE to today! I will configure it with Ethernet and see what happens.
The problem is solved, it may have been a cable / connection issue (I used another one, it worked well, and again with the first one, it worked also).
Tony one last point for you if I may. Is the BlueNode compatible with cat7 ethernet cable ? Will there be any difference ?
Thanks
Cat7 is backwards compatible so will be fine to use, however won’t give you any benefits apart from costing more.
11 comments
