6 comments
    Hi Mike
    Your BluOS Player should prompt for update when one is available. To manually check for update, select Help, Check for Update in the BluOS App.
  • Rene Biard
    Dear, I own a Bluesound Node, but since the last update Bluos 4.0.5 the sound is terribly worse than the Bluos 4.2.0 firmware Reset does not help... Could you please send me the previous one, the 4.2.0. Yours sincerely,
  • Morten N.
    Brand Manager
    Hi Rene,
    Which product do you have? Latest official firmware is 4.2.6.
  • Permanently deleted user
    Yes 4.2.6..but4.2.0 was such a nicer sound.
    Hi Rene - I would reboot your system. No changes to DSP were made in the maintenance release to BluOS 4.2.6 from the 4.2.0 release.
  • Rene Biard
    That's really strange? I shell reboot the system again.
    Thnx so far for the quick response
