Streaming transport using BluOS?
6 comments
    HI Jeremy - The NODE is in fact the product you are looking for.
  • Jeremy Gilbert
    Thanks Tony. That's what I keep coming back to, it's just a shame about the redundant DAC. Ah well.
    Is there much difference between the Node 2, 2i and the new (2021) Node when used as transports?
    Better wi-fi chip, more options on the now proximity touch panel, a next model DAC chipset and USB output are what was added to the new NODE N130.
  • Jeremy Gilbert
    Cheers Tony, better WiFi may swing it but the other features are redundant for me.  Many thanks for the swift responses, it's much appreciated
  • Svetlin Simeonov
    Don't forget the better/faster CPU which should provide faster operation.
    If you want just BluOS, the Node is your cheapest option (Node 2i even cheaper). There is no other way for you to get the OS!
  • Jeremy Gilbert
    Thanks Svetlin
