Bluesound Node N130 does not accept audio input via HDMI from Blu Ray player Sony UBP-X800M2
    Bjørn Ulvik
    Not sure why you are connecting your BD player to the Node?
    Connect SPDIF directly to your HiFi system from your BD player.
    HDMI input should be PCM. Setting DSD output to off, and Digital Audio Output to PCM could probably resolve your issue.
  • Harald Berger
    It is a really old Hifi System without any digital input, but a good sound.
    That way the trial to use here the Bluesound here.
    And the HDMI output was PCM and DSD was disabled and this does not solve the issue.
    Is there any log file, where I can find info, why the Bluesound fails?
  • Bjørn Ulvik
    Is "Auto Sense" on for the HDMI. If not, try pressing the "play" button in the app/controller after switching source on your Node.
    Could be cable issue if there is no sound. Have you tried connecting your TV to the Node with HDMI with the same cable?
    No log file, but if you select "Help, Send support request", you will eventually get one.
