USB vs COAX and DDC usage
5 comments
  • Greg Pugh
    Andrea,
    1. USB output sounds better than SPDIF on mine. But a lot of this is going to depend on your DAC and the particular implementation and combination of DDC etc.
    2. There is a pretty significant bug in the implementation of the USB output on the new Node that makes the volume not actually fixed for a number of DACs (and apparently DDCs). Bluesound support is very defensive of their software updates and usually blames users for any errors in their implementation, and then backtracks once enough people report the problem and they release a fix. It's a weird system, but hopefully there will be an updated patch soon that fixes the issue with certain DACs and maybe DDCs as well.
    2
  • Andrea Crema
    Thanks Greg for this answer.
    My observations seem to indicate that USB is slightly better and provides more separation. I am currently using a Denafrips Ares II which I think has a pretty good USB implementation.
    On the question of DDC, I was planning on getting maybe the Denafrips Iris, but I'm hesitant now after the statement from Bluesound that it could degrade the signal. I'm not really technical enough to understand but have also emailed Denafrips for their comment.
    Interestingly I have noticed the that the Node identifies my DAC and firmware version in the app, but as you say the output is no longer fixed like it was before.
  • Simon Goodale
    With my Chord Qutest, I still prefer the coax out to bnc with a decent Atlas Hyper rca to bnc cable. My USB cable is a fairly old Wire World one so not really a fair test
  • John
    If using a ddc on the USB output of the NODE, if the ddc is capable of "seeing" and therefore doing what it's designed to do... improving/ reducing the jitter (that WOULD be there to some extent) why would it not?
    The dac section's performance of the NODE, wouldn't have anything to do with the digital output at the Node's USB?
  • Steven
    Greg,
    I've been frustrated with the same issue regarding the volume control graphic still displaying while outputting via USB.  Also frustrated with Bluesound's (Tony W's) response how it's "my dac's fault" because it's a DDC.  But aren't they all? I cracked open my DAC and the USB interface board is just a daughter card feeding I2S directly into the SPDIF board, which then goes I2S to the DAC board.
    Tony if you're reading this, I'll say it again, the Node is obviously already aware of when USB is being used, as the output is indeed fixed, so ALL YOU HAVE TO DO IS DISABLE THE VOLUME GRAPHIC FROM EVEN SHOWING.
    I finally found a way to make it appear fixed.. In the Audio Settings, you'll see your USB output chosen. Go back and select Default again, then when you select USB you have to QUICKLY tap the Fixed Output option before it disappears.
