HOW DO I DELETE INDIVIDUAL SONGS FROM PLAYLISTS USING IOS CONTROLLER
AnsweredI saw an answer to this dating back 4 years which no longer works. It said on iPad, swipe left on the song in the playlist then hit delete. Nothing happens when you do this. The obvious thought is once in the playlist - click the three dots which lists a few options (including "add to playlist") but there is no delete from playlist. Any thoughts?
A way to do this on either ipad or Windows app would be appreciated.
Open a playlist so the tracks are then added to the playing queue (best to empty to queue first) then you can remove the tracks and save the playlist either as a new name or overwrite the existing.
https://support.bluos.net/hc/en-us/articles/360036112673-Creating-and-Managing-Playlists
Thanks!
Never really noticed the "play queue". That worked - thanks!It's all making a bit more sense now!
