BluOS playlist issue
Hi,
I've reported a BluOS playlist issue on iPAD controller app almost six months ago and got an answer from your team that it would be fixed in the future.
(Please see detail below)
BluOS controller is now updated to 3.16.1 & BluOS 3.16.2, but this issue has not fixed yet.
As you see this is the very basic function/operation of BluOS playlist for anyone. When will this issue be fixed?
------------- Six months later --------------------------------------------------------
This issue has been fixed on BluOS Controller App 3.18.1, many thanks to Development Team!
Hi all,
There is a workaround for this problem.
In my case, I made up many BluOS Playlists which contain thousand of music tracks. (My library & Amazon Music mixed)
Small playlist (such as 200-300 tracks) works fine on iPad but one thousand or more do not.
The playlist itself is able to contain up to 9999 tracks I tested and confirmed.(Workaround)
I setup "preset" for these playlists. Curiosly it works fine. (for 5000-7000 tracks playlist)
So I think that Blueos Controller on iPAD itself has the ability to put a huge playlist into queue.
(Tested Summary: 7000 tracks BluOS Playlist)BluOS Playlist --> Preset --> Quese ---> OK (on iPad BluOS Controller)
BluOS Playlist --> Queue --> NG (on iPad BluOS Controller)
BluOS Playlist --> Queue --> OK (on Windows BluOS Controller)
Post is closed for comments.
