Wifi issue during initial Node N130 set up
AnsweredHi team,
I've tried to set up my new Node N130 but failed.
1. I reset the Node
2. I found it in WiFi section on my Iphone XS.
3. Connected via AirPlay
4. Opened the app and found it.
5. But it couldn't connect to my WiFi (the screen below). I tried 2,4 and 5 Ghz networks, reset my router and got the same error. I was really close to the router.
How can i try to connect by Ethernet cable?
Kind Regards
Konstantin
Hi Konstatin
All your setup questions and variable options can be answered at www.bluesound.com/setup
This players sucks ! The 5G issue is really sad, this must be the only player that won’t connect to a 5G unless someone here has done it and can share
Hi Luis - your post is answered here; https://support1.bluesound.com/hc/en-us/community/posts/4419677070743/comments/4419719422103
Post is closed for comments.
