Same problem again „Constant dropouts with Spotify connect"
You wrote: Reboot your network router, wait 5 minutes, reboot any wireless extenders, wait 5 more minutes, reboot your BluOS Player wait 5 more minutes. This will clear any network routing issues that are causing network dropout.
That only helped for a short time. Same problem again. Al my other Spotify connect devices have not this problem. Node2i became crap after the last firmware update. Sorry for the the hard words.
Hi Karl...
likely if I said that - I also would have added "...if problems persist, please select Help, Send Support Request in the BluOS App so our Support Crew can provide 1 on 1 troubleshooting in your environment.
Post is closed for comments.
