TuneIn favorites randomly change - proposed solution doesn't work
AnsweredHi! I currently own a Bluesound Node 2 and a Powernode 2. I have a problem with the TuneIn favorite radio stations. The ones you save as a favorite get removed over time and random radio stations pop up. So I searched the forum and applied this fix:
https://support1.bluesound.com/hc/en-us/articles/203993688
Unfortunately the problem still is present. I also noticed my personal TuneIn account has been overwritten by an account named 'control999hc'. Do you have any other tips / solution to this? Thanks for your reply!
HI Gerwin
Please select Help, Send Support Request in the App and our SUpport Crew can provide 1:1 Support to further assist
Since a repair on my Node 2 I have the same problem. It seems like someone under my account is changing the channels. What can I do?0 -
Hi Barbera - if the above Help Centre Article (https://support1.bluesound.com/hc/en-us/articles/203993688) does not work, please select Help, Send Support Request in the App so we can take a closer look.
