Will the Powernode 330 work with Sonus Faber Lumina 1?
5 comments
    Hi Victor
    The POWERNODE is 80 watts at 8 Ohms (not 4 Ohms) that's closer to 160W at 4 Ohms. It might be a bit much for your speakers based on the specs you posted.
  • Victor Lindgren
    Is it! ? wow. Then i will go for the Sonus Faber Lumina 1, cuz it wont be a trouble that it is to much cream in the powernode  - right?
    Thanks for the answer!
    I just compared the swedish (hifi klubben) specs to the bluesound homepage.
    Rated Power Output - 80W x 2 (8 Ohms) - YES!
    It might just be a failure on their site!
    In swedish =)
    Hi Victor
    I was unsure of the numbers so I double-checked this with a Home Audio Specialist with our good friends at NAD Electronics - here's what he had to say;
    As the Sonus LUMINA I suggested amplifier power output = 30 – 100 W, and the Powernode N330 Output power = 2 x 80 W (8 ohms) into 4~8 ohms (same as C368/C268 power rating), I think they will provide solid sound performance.
    He also sounded a little jealous... enjoy
  • Victor Lindgren
    Bless! Thank you so much!
    (and the Hifi klubben Sweden has changed their N330-spec on the wedsite)
  • Robbie T1974
    I have got a pair of Lumina II's connected to my Powernode N330 here, sounds great, the amp has plenty of headroom for these speakers.
