Unable to send full-range signal to both mains and subwoofer?
    Hello Mark,
    Even with the Subwoofer switch set to OFF, the SUBW OUT on your POWERNODE should still send signal to the sub at the set crossover. Please reach out to our support crew with the make/model of your sub as well via Help > Send Support Request in the BluOS app so they may investigate.
  • David R
    Helo Mark,
    Earlier, like you wrote, the subwoofer would still receive current when the Subwoofer switch was set to OFF. 80Hz or the entire spectrum, I cannot remember.
    Unfortunately, Blusound has changed the behavior out of nowhere. Now, when the Subwoofer switch is set to OFF, there is 0 output to the sub.
    Turning the Subwoofer ON, dictates a crossover and indeed, a high pass filter to the main speakers, this is very strange and absolutely unacceptable that Blusound suddenly change the behavior of their products after all these years, without notifying the user nor giving the user the option to opt-out of this dictatorship.
