Wired-headphones volume (PowerNode)
    Davywhizz
    I found the headphone volume on the Node 2i wasn't enough for my AKG 702s. I added a small headphone amp/DAC using the digital coaxial output and it works well. One of the great things about the Node (and thus the Powernode I guess) is that  all the outputs are live all the time with no need to switch between them. If I use headphones I leave the main hifi amp off, headphone amp off for speakers. I just have to remember to adjust the subwoofer switch in BlueOS to get full range to the headphones.
  • Ken
    From what I remember using Koss PortaPro with PowerNode 2, volume level was not a problem (at regular volume setting).  Sound quality was only serviceable.
