Node Outputs Concurrently Hot?
4 comments
    Yes - all outputs are active
  • Jeff Thomas
    Excellent. Thank you!
  • Santo Scarpinito
    Dear Tony I see that you indicated that all outputs are hot.  However are they in sync?
    The signal leaves the NODE in sync...  however I have seen many cases where an outboard third-party DAC would add additional delay enough to make it appear out of sync, even when grouping two separate NODEs never mind using one NODE with two outputs.
