Bluesound Node 2i - USB Drive Suddently Not Indexing
Hi,
I've been using the same USB drive for the past year I've owned my node and have never had any issues. Recently I removed the drive to add more songs to it. When I reconneted it, the USB drive never appears in the app. I tried to rebuild the index and it says it's starting indexing hits 1 file and stops and the drive never shows up. If I connect a different USB drive it starts indexing and working normally. I also tried deleting all the new folders and files I put on the drive but it still fails. What could be on the drive preventing indexing?
Thanks
....I also tried deleting all the new folders and files I put on the drive but it still fails
After deleting, empty recycle bin -
If the above advise does not help, try power cycling the Node.
Still no joy... then plug the USB drive back into a computer, format it and add just a few track to test again. Warning when you format the drive everything on it will be deleted.
I tried emptying the recycle bin, doing the diagnostic reboot and then cycling power, none worked. Last step will be to format it which I want to avoid. I miss CDs..
It may be too late to rescue your music but in the future, it may be a good idea to have a more permanent solution; https://support.bluos.net/hc/en-us/articles/360000465747
A USB Drive plugged into the back of your node is quick access to music but note a permanent solution
4 comments
