Multi-zone streaming distribution
12 comments
    Hi Greggo
    Speak with your Bluesound Authorised Reseller about the NAD CI580 from NAD Electronics (a sister Brand).
  • greggo
    Thanks, I was hoping to get some consumer grade equipment that doesn't require special automation software.
    The NAD CI580 uses the exact same software - think of it as 4 nodes in one box
  • greggo
    Actually the CI 580 is a very interesting product, but it does not solve my issue of a multichannel amplifier capable of independent channel remote (RF or WiFi) power control.  Preferrable the inputs can be global to one line level source and a bonus would be to operate several channel in bridge mod
    -1
  • Yves
    Hi Greggo,
    What did you end up doing?
    I'm in more or less the same situation.
    Audio system in the kitchen. There is an adjacent room which has speakers and I want to be able to switch on and off those speakers easily (preferably with push of one button). Good old amps had A9B speakers.
    Good luck finding a receiver with DAB, Roon support and A+B posts that support 6 ohm speakers.
    This has been driving me crazy. Currently only option I see is using multiple powernodes or using 1 node with Y-splitter going to multiple power amps (e.g. Tangent Pwerampster 2).
    Thanks
    Yves
    This option sounds like a troubleshooting nightmare...
    Consider an NAD M10v3 or C700v2 in the main room and a POWERNODE EDGE or even a PULSE M on the counter for the Kitchen. They will run together or independently when you want either option.
    BluOS does not support DAB but does offer multiple options for digital Internet Radio Streams depending on your region. TuneIn Radio is supported by over 10,000 radio stations around the world.
    Speak to an authorised BluOS Dealer near you for options www.bluesound.com/stores or www.nadelectronics.com/dealers to locate your nearest one.
  • Yves
    Many thanks for a very quick reply!
    I agree with you that using external amps will be tricky.
    However I do have some issues with the solutions you propose:
    - Using mutliple streamer/amps such as the powernode or the NAD seems to be the way manufacturers are solving multi zone playback. I find grouping and un-grouping very complex. It used to be a push on a A+B button. Now you gotta go in the app, group or- un-group, etc. I find that to be not very handy in BluOS (and in Roon). I did submit a request to Roon to have devices in multiple groups and separate at the same time avoiding the group/un-grouping.
    - TuneIn has become a nightmare since they introduced more advertisement. I understand they have to make money. But the regular interruptions (on top of the adds from the radio stations), where music just stops, no sound for seconds, an add (if you're lucky) and then the music to resumes. That is not good. You can find many people complaining about it on various forums. I have given up on TuneIn. Internet radio works great via Roon. DAB is just too easy and ... well ... just works.
  • Permanently deleted user
    Yves, I went back to a DAB+ tuner earlier this year but sold it on quite quickly.
    Firstly the audio quality on both FM and DAB+ is not a patch compared to the FLAC radio streams available. Secondly it was not as quick and easy to switch to the Tuner and sometimes required the use of the App. So now I have the streams programmed into the Bluesound RC1 remote control and it’s super easy with a single press to play a station and at a predetermined volume level.
  • greggo
    HI Yves,
    I ended up going with 2 Nodes.   One connected to my media room 7.1 system (5.1 + 2 Atmos speakers) for stereo listening.   The other sources a multichannel Dayton amp with 8 output zones (I use all 8 for 8 L+R pairs) controlled by their IOS app (individual zone control of volume, on/off, mute, and basic EQ).
    I use either BluOS (which I like) or Roon (love/hate relationship).   Roon in the media room is controlled by a 3rd party app running on Apple TV and a universal remote configured to display Roon on my TV and allows the remote to do basic Roon function (search and select, volume, zones, etc.).  That avoid firing up an IOS app.  I'd love to have the BluOS interface on Apple TV for this reason
    Its a pain having multiple apps source and speaker control and I've a background project to put everything on a customized (by me) tablet specifically for audio using Home Assistant and some 3rd party user interface 'tile' apps.   The group/ungroup will be a single toggle for the 2 nodes.   FWIW when using Roon the endpoint in the media room is my stereo amp, not the Node.   The media room node is only used for BluOS applications
    It's been an adventure :).... good luck
  • Yves
    Thanks for the feedback!
    Interested in the 3rd party app that offers you the option to easily group/ungroup
  • greggo
    It's called 'TV:Remote' in the Apple TV App store.
    It basically put the Roon interface on the TV to allow navigation by the Apple TV remote.  I prefer it, esp the ability to see album info on the TV, over using the IOS Apps
    It's the Roon interface, so if you don't like it for managing groups this would not be any different
  • Yves
    Oh ok!
    I already have TV:Remote. Handy indeed.
    Still find managing groups annoying ...
    If I could configure one of the buttons on the BlueSound remote that would be something ...
