Can I use two different models of Bluesound Node using same wifi network?
4 comments
    Avatar
    Alain DW
    I should think so, Bluesound being multiroom. I have a Node2 in the living area and my son has a Node2i in his room and they are on the same network. They can play independently our grouped.
    However the players share the same library which in your case will be wanted. I would have liked the shares separated because my son has a very different taste of music, but this is only a technical detail and has no influence on the daily use.
    Comment actions Permalink
  • Avatar
    Josh L
    Alain, thanks for your reply. So Node 2 and Node 2i works fine  and can be grouped. That's good to know. I'm wondering if N100 will do the same.
  • ALL BluoS Players are designed to work together, this includes the original NODE N100 playing nicely with our latest NODE N130 and N330 just released this spring.
  • Avatar
    Josh L
    Tony, thank you for confirming that.
