Blusound Node2i using Big Sur on MacBook
    Hi Colks
    Here is how to reset permissions on your MacBook - https://support.bluos.net/hc/en-us/articles/360000485508. Once completed, please select Help, Diagnostics, Rebuild Index to purge and reset your Local Library database.
    If problems persist, Help, Send Support Request in the App.
