Spotify Connect lose connection when player is in pauze mode
AnsweredI play some tracks via Spotify connect to my Node (2021).
However when I put the player in pauze by my Android smartphone and leave it in this state for some minutes (for answering a phone call by example) and try to resume the track, then the spotify connect is not active anymore and my smartphone will play that track by its build in micro speaker.
Is this a setting or timeout that can be adjusted?
Check for upgrades to make sure you are using BluOS version 3.14.26
If this does not help log a support ticket from the Bluesound App... Help...Send Support Request
That version is already installed one week ago.
I will create a ticket.
Tnx.
