Node2i sound softer and duller after software update
Answered-
In the latest update there was nothing altered that could affect audio quality and yours is the only post here regarding an issue with audio so very curious. Could be the Node, the leads, the power amp or something else that’s part of the chain. Simple things like one the speaker leads being swapped could produce a similar effect.
Do you have another source you can use in place on the Node, so still using the analogue leads from the Node to your power amp but replacing the Node with an CD / DVD / Blu-ray player and see what happens?
Thanks Seppi.
I have checked all the connections and cables. Will try another source and see. Thanks.0 -
Hey Seppi
I checked with alternate sources and the Node sounds significantly better in comparison. Thanks for your advise on the A/B test. I appreciate it.0
